RV-7A Construction Log
RV-7A
Fitting the Canopy Frame to the Fuselage 10
I'm studying the drawing for how these side rails fit. I'm going to need to read some other folks construction logs to see what I might be missing.
I went ahead and laid out and pre-drilled the holes on the C-613 splice plates. The plates attach the side rails to the forward frame.
Drilled the splice plates
Seems like fit is okay
Drill these angles next.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
