RV-7A Construction Log
RV-7A
Drilling the Hinge Brackets 4
I pushed down the hinges again with a hammer. Probably shouldn't have pushed down so hard, because later you'll see the skins hit and the frame won't open.
I used the angle drill and it worked fine to make a small 1/4 inch indent on the hinge.
Holes looked fairly centered.
Whacked down the hinges
Drilled with angle drill
Indent looks centered
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
