RV-7A Construction Log
RV-7A
Canopy Install: Aft Canopy Latch 2
I used the 1/8 angle drill to drill only 1/16 deep marks on the bearing blocks.
I removed the blocks and drilled them thru on the drill press to ensure the holes go 'straight' thru, not at any angle.
I bolted this aft latch in place.
Drilled 1/16 hole to mark location
Drill blocks on drill press
Bolted in place
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
