RV-7A Construction Log
RV-7A
Fuselage Final Items: Electric Aileron Trim 3
The bracket gets trimmed in length and two holes match drilled to the floor using existing floor holes.
Then you remove the two platenuts previously put on the two center floor ribs. Platenuts on the bracket will be used instead.
Then two additional holes get drilled in the bracket and floor ribs 1 1/32 below the existing holes. These will be dimpled and hidden under the floor.
Match drill these two holes
Remove platenuts
Drill two new holes
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
