Brief Description: Fuselage Final Items: Air inlet scoops 6
I installed the pulled rivets and will leave it clamped till tomorrow. The flush heads are fairly flush. The mfg side has a little head that grabs the spacer and holds inlet in place. You can see the square washer on the back side in photo below.
