RV-7A Construction Log
RV-7A
Front Deck (Tip Up) 7: Make Angles
The center angle got drilled the same way using the accordian jig. But this one doesn't get cut outs. Instead it gets fluted to fit the slight curve.
Drilling the straight angle
Again hole spacing is perfect
Flute this angle to fit curve
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
