RV-7A Construction Log
RV-7A
Front Deck (Tip Up) 1: Make Angles
Time to start the front deck. I'm painting the roll bar parts while I start the front deck.
The front deck starts with making angles. The little ones are easy. But there are a few with cut outs.
I cut the stock to length, measured and mark hole locations. And I used my protractor to mark the 15 degree cut off lines.
Small angles are easy
Cut long angle to length
Mark the 15 degrees
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
