Continued on building the rudder and rudder skeleton.
DWG-7
Started the day manufacturing the R918 Bottom Attach Strip – this took some time because I couldn’t find the raw material… but I finally did. Fit the R918 and matched drilled to the bottom rib.
Started to dissemble the rudder, but stopped to alter the 601 skins to fit in the R405 Horn (per plans)
Assembled the counterweight, matched drilled and countersink.
Took the rest of the rudder apart and deburred, dimpled, cleaned and primed (some parts). No photos –
