Brief Description: Mounting/connecting the engine ECUs
I mounted the engine computers on the backside of the mount I made for the fuel pumps, which will hang from a support bar under the luggage platform. I connected the 37 pin harness from the engine, and then finished the following connections:
ECU main power ECU backup power ECU 1 ECU 2 ECU select
There are many more connections I'll have to finish here, but this is enough for now to allow me to start the engine.
