Installed the pitot tube. It required a 5/8" hole, and the largest drill bit I had was 1/2", so I used that and enlarged it from there with the Dremel. From the strut to the float support, the angle was so much that the tube was bending and collapsing, preventing a good reading, so I added some 90 degree transition couplers at that point, and now the airspeed seems to be working well.
Hole drilled for the pitot
Pitot installed
Pitot and AOA connected to the tubes going to the ADAHRS
