Brief Description: Fabricating the panel plates, part 2
Cutting the fiberglass panel to hold the avionics plates. This is a bit tedious also, because you want to cut enough to clear all the avionics, but leave enough to support the plates.
Of course, these panels will eventually get the same grey paint.
Pilot's main panel cut
Test fit
Cut for three plates, and testing fit back on the plane
