One of the last things to do to finish up the wiring, just had to split the wiring out for both wings, run the ground wire, and add quick connect terminals. Each side has a blue "sync" wire that will connect to each other, so the strobes will work in unison.
Connectors coming out of the wings (wings are still on the garage floor, but not for much longer!)
