Project Blue Angels SeaRey
Date: 11-25-2013
Number of Hours: 8.00
Manual Reference: None
Brief Description: Wiring all EMS sensors, part 1
Now that the engine is running and all the switches are doing their job, now I wired all the engine management sensors. At the engine, this was the gear temperature, coolant temp, oil temp, and oil pressure. At the station I created to hold the fuel pumps and engine ECUs, this was wiring the fuel pressure and fuel flow sensors, along with certain engine signals such as the tach/RPM. I spent an enormous amount to time protecting all the wiring with sheathing and securing it where it couldn’t move.
I still have a few wires to connect to the Dynon EMS computer in the avionics tray, but at this point, I should be able to configure the EMS serial connection in my EFIS, start the engine, and I should start seeing certain engine statistics come up on my flight display.
All sensors wired on the engine
All sensors wired at the fueling and engine computer components
Fueling and engine ECUs wired and mounted
