Project Blue Angels SeaRey
Date: 9-22-2013
Number of Hours: 4.00
Manual Reference: None
Brief Description: Finished the wiring around the batteries
I finished all the wiring around the batteries. I’ll have some tidying with a few wires, once I know it’s all working correctly.
As far as the panel, I’m not going to cut my real one until I’m 100% everything is working and I am happy with the layout I designed, so I created a temporary panel and so far, installed the EFIS, ignition switch, and parking brake. I’ll slowly start filling it up as I go along wiring.
I couldn’t help myself… although I’m still waiting on the computers to run the engine from Viking, I have enough hooked-up to see if I’m getting power to the starter. I turned the key on the ignition switch, the starter engaged, and the prop turned. Very exciting! Unfortunately, the starter engaged when in the keyed “ON” position, instead of “Start”, so I’ll have to track down that problem…. which should be no problem.
Dual batteries, contactor relays, main 200a fuse, shunt
Termporary panel with EFIS, ingition switch, and parking brake installed
