Slowly getting all the wiring in place. I've been running it out to every place it needs to go, and wrapping it all with protective insulation as I go along.
I began hooking up the parking brake also, but the kit doesn't give you enough brake line to run to that and back to the gear, so I've got to order more of that. For the past five or six weeks, I've had to put in a large order to the aircraft supply company weekly, and I really thought I had done well in thinking ahead to all I'd need, but that's just impossible when building a plane.
Starboard side wire run all the way out to the engine
