Wiring the center console. I knew I wanted to run this wiring through the cockpit tubing, so I intentionally didn't add any connectors when working on it inside, until after the wire was in place. I wired it all through the center cockpit tube and added quick-connects to everything which goes there, which is landing gear switches, circuit breaker and lights, and the flaps controller.
