Project Blue Angels SeaRey
Date: 6-15-2013
Number of Hours: 12.00
Manual Reference: None
Brief Description: Wiring, continued
Well, I'm out of wire, connectors, and label tape, so I've done as much as I can do until more parts come in next week.
The process of wiring has me really thinking through any parts left to get in order to finish up the plane. I've got another fairly large Aircraft Spruce order I'm putting in of various capacitors, relays, wire, etc. This is the toughest part of the build, because wiring is so complicated, but also, none of it comes with the kit, so it takes a lot of research to figure out what's needed to run everything.
When wiring, a good label maker is your best friend
