Project Blue Angels SeaRey
Date: 3-14-2014
Number of Hours: 4.00
Manual Reference: None
Brief Description: Adding vortices generators
Adding vortices generators to the wings. These come with a template you cut out to guide where each one should go along with the orientation. What I learned was, cut out the template large enough that you can place the VG on the wing without getting any glue on the template, because it will quickly glue the paper template to the wing. 36 per wing.
Another thing accomplished today, I re-installed the engine computers, after sending them off to get updated with the latest programming. Upon starting the engine, I could tell the engine is running smoother, and the air/fuel ratios are running in a better range. Before, I'd start the engine, and at idle, the ratio hovered around 11.5, which is much too rich for idle, but now it's about 13.5 - 14.0, which is just right. Will test on the water tomorrow, to see the range at wide open throttle, and any performance gains.
Using the template
All done left wing
