Brief Description: Section 34, upper gap seal, part 2
To fill in the area left due to the different engine, I riveted more material onto the gap seal, I had a long enough piece that I could overlap five inches, and have it go most of the way back on the wing, with a section cut out to follow the contour of the wires and support under the engine. I put some trim molding on what I cut out, to ensure it doesn't chafe any wiring.
