Brief Description: Section 17, root tube and electric flaps
Installed the root tube that will hold the wings and engine, and then installed the electric flap actuator. Other than a few bolts the wrong size, the manual was fairly accurate and an easy, straight-forward job.
Root tube installed
Electric flaps actuator
Actuator is connected to the Flap Slave Horn by a tie rod
