Project Blue Angels SeaRey
Date:  12-29-2012
Number of Hours:  6.00
Manual Reference:  5.9 - 5.14
Brief Description:  Section 5, frame finally in place
Much of today consisted of hours of measuring. Everything seems to fit perfect, except for a 1/4" space on the left transom bracket, while the right one was flush. I concluded that my hull, especially the back, is not perfectly square. Eventually, I picked-up the back of the hull and moved it, and learned that it was binded and twisted a bit, the way it was sitting on the bunks, so after that, everything fell into place where it should be. Whew.
Although I cut the slots around the bulkhead cross tube perfectly, I spent some time today fabricating some aluminum plates that will go around them, to give a cleaner look and hopefully protect the fiberglass from cracking.
Also spent a great deal of time double-checking all torque values on the hardware holding the frame together, and marking the bolts.
I am to the point of cutting out the holes for the landing gear. I ran across two pieces the factory needs to send me today, so after I make these cuts, I may have to put this on hold and tackle something else, while waiting for parts.
Hull meets airframe
Hull meets airframe
Fabricated stringer brackets in place
Look at that perfect cutting job.
