Brief Description: Made brackets to help secure the airframe to the h
Although the factory said this wasn't necessary, like many other builders, I am not comfortable with the airframe only connected by seven bolts through the wooden hull stringers, so I fashioned-up some brackets I'll use to attach to the stringers, then I'll drill a hole through these to secure the airframe bolts. Should eliminate any shifting of the airframe, once in.
