Had to begin working on something else, while waiting for my fuel tank to come in, so decided to go ahead and jump to section 9 and get the main landing gear built. Everything by the book, except I drilled an extra hole to run the brake hydraulic lines up the gear legs. I don't understand why the manual still runs them to the outside; makes it look so unclean. I was also a bit confused at the end regarding the orientation of the brakes, until I realized that the caliper faces forward on one side, and faces to the rear on the other wheel.
Wheels assembled, shown before inflating
Modification: hole drilled to run brake line internally
Legs, brakes and wheel done, ready for final assembly
