Project Blue Angels SeaRey
Date: 8-26-2013
Number of Hours: 4.00
Manual Reference: None
Brief Description: Installing the engine, part two, lock it down
Now that the engine was securely in the air, I rolled the plane underneath it and lined up the back bolt to secure first, since that hole already exists, after I drilled it out with a 3/8" bit to hold a larger AN6 bolt.
After the back bolt was in, I marked and drilled right in the middle of the root tube, where the front bolt was secured in place.
The front bolt required is an AN6-31A, and the back bolt, AN634A.
Up til now, this might have well been a giant airplane-shaped paper weight, but today and going forward, it is an official aircraft with an engine!
Moved the plane underneath, and lined up the back bolt
Back bolt in, marking where to drill for the front bolt
ENGINE INSTALLED!
