Project Blue Angels SeaRey
Date: 1-21-2013
Number of Hours: 1.00
Manual Reference: 17.6
Brief Description: Section 17, still fitting the turtle deck
Another builder contacted me and said that if I had to trim so much off the turtle deck, to make sure to test fit the turtle deck angle brackets that go on the mid-root support and bolt to the top of the turtle deck. In the test, I didn't have enough room to bolt them in, but only because I have an 1/8" of sound proofing and another 1/8" layer of carpeting. I marked where the brackets will go, removed the deck, and cut some tabs in the carpeting for the backets to go; now a perfect fit for those. Once installed, it'll look nicer with the carpet glued over the brackets to hide them anyway.
While the deck was off, I used a file to smooth out any rough spots on the edges, and cut the carpet back 3/4", as to not get in the way of the area to be riveted.
I'll perform one more thorough check on everything residing in the aft hull before permanently putting it in place.
Turtle deck now ready to be riveted to the hull
