Project Blue Angels SeaRey
Date: 12-30-2012
Number of Hours: 1.00
Manual Reference: 5.35
Brief Description: Section 5, installing bilge thru-hull
Easy stuff, just drilled the hole right where the manual suggested, which was perfect. If you secure the pump where it should go, it's too hard to get to underneath the fuel tank, if ever needed, so I attached the lexan strip, the factory was nice enough to include, to the pump and screwed the lexan under the bulkhead, but not crazy about how flimsy the lexan is. Just attaching this tube twisted it and had the pump high in the air, where it wouldn't pump any water out if it had to. I'm going to consider using something more firm than the lexan, because that's just going to flop around and get on my nerves, plus it's a safety issue if it can't pump out all the water.
