Brief Description: Continued working on the wing skins
Started the process of getting the skins ready to rivet. Each skin was pulled off the wing and put thorugh the process of removing the protective plastic, dimpling and then priming those areas of the wing sking that contact the wing ribs. You can see in image two the priming stripes. The areas that are not primed still have the protective plastic. I will pull that off after riveting the skins.
After finishing each separate skin I started to reinstall the skins. I am waiting for a pitot tube that will be installed on the leading edge, so until that shows up the wing skin installation stops.
