Scott's Aircraft Build Logs
Date:  1-1-2007
Number of Hours:  3.00
Brief Description:  Van's class project
I continued to work on the class project. Afte fabricating the two construction aids I finished drilling and riveting the spar to the ribs. Then I fitted the two skins and matched drilled all the holes. Of course that means taking it apart, deburring the holes and dimpling everything. I can see why it takes some time to build an airplane. There will be a lot of time spent on deburring and dimpling when the kit arrives.
