Sid & Houston Mayeux Project
Date:  10-31-2014
Number of Hours:  3.00
Manual Reference:  Wheel Pants
Brief Description:  Installing Wheel Pants, part 7
I taped two sections of 0.063 and 0.032 ALCLD together and used those sections as shims between the wheel brake discs and wheel pants brackets: These should give the brackets some strength and rigidity when I drilled into them from the outside. I marked drill points onto the pants brackets: Black dots that I could see through the translucent wheel pants. With the wheel pants aft halves aligned and mounted, I installed the nose caps then drilled through them into the pants brackets, creating the screw holes.
Shimming the pants brackets
Drilling the nose cap screw holes
Mounted and aligned
Mounted and aligned
