Sid & Houston Mayeux Project
Date:  10-30-2014
Manual Reference:  Wheel Pants
Brief Description:  Installing Wheel Pants, part 5
The wheel pants' center aft end must be aligned perfectly with the tire's centerline, and positioned 8 5/8" above the floor (aircraft lifted and level). I created billboard-style reference boards with an exact centerline drawn all the way around it, front and back. I then marked and drilled a reference point exactly 8 5/8" up the front face: The hole will allow a small length of piano hinge pin to stick out.
I then drilled a #40 hole in the exact center of the wheel pants' center aft end. With the pant in place, and the billboard sitting on a tire center reference line, I can stick the pin into the wheel pant center aft end hole, thus perfectly aligning the wheel pant on center and in height.
Crafting the alignment templates
Marking tire center reference spots
Checking the height/alignment
