I installed the two transponder antennae in the forward corners of the cockpit floor. I used RG-400 cable. The left antenna is for the integrated SkyView transponder. The right antenna is for the SkyView ADS-B IN unit. I'll remove these antenna shortly to prep for the airplane's movement to Texas in April.
