Sid & Houston Mayeux Project
Date:  3-25-2015
Number of Hours:  3.00
Manual Reference:  Cockpit/Canopy
Brief Description:  Clean-up items
I took a few hours to knock out some finish items and make improvements.
Image 1: I installed Hooker Harnesses that I bought from Terry Wallace. The color will come close to matching the blue in our cockpit.
Image 2: For the cockpit floor center section, I replaced the foam-style padding I used to pad the aluminum floor from the fuel lines and wiring. Instead, I used heat shield which also has a padding quality. I also expect it to keep heat from the exhaust pipes from impacting those lines in that area.
Image 3: I used malleable aluminum foil tape to seal the flange shelf on the cockpit sub-panel underlying the forward canopy skin. This should help keep rain and wash water out.
Installed the Hooker Harnesses
Replaced the padding under the cockpit fuel lines/wires
Improved the forward canopy flange seal
