Sid & Houston Mayeux Project
Date:  3-15-2015
Manual Reference:  Weight & Balance
Brief Description:  Weight & Balance, part 1
I accomplished the aircraft weight & balance today. With all fairings and panels in the aircraft, plus seats, carpets, fire extinguisher, and 8 quarts of oil, I used a plumb bob to mark the wing's leading edge (LE) on both sides in front of the main wheels, and marked that spot on the floor on masking tape. I then marked the exact center of each main and nose tire.
Knowing that the CG datum reference is 70" forward of the wing LE, I then measured the distance from the LE aft to the main tire center, and forward to the nose tire center. This gave me the exact arm lengths for each side.
Everything's on the airplane
Bobbing the wingtip & tire reference points
Measuring the main tire arm
