Sid & Houston Mayeux Project
Date:  3-9-2015
Manual Reference:  ELT, Center ribs
Brief Description:  Mounted/tested ELT, sealed fuselage center ribs
I installed new D-cell batteries in my Emergency Locater Transmitter (ELT), mounted and connected it in the aft fuselage, and tested the ELT. I got a good beeper on my hand-held VHF on 121.5 MHz. I logged the install and test in the aircraft log.
I installed the pieces that bridge and seal the gaps in the mid-fuselage center section ribs over the control column push-rods.
New ELT batteries
New ELT batteries
ELT mounted, tested, armed
Fuse center ribs sealed
