Sid & Houston Mayeux Project
Date:  1-16-2015
Number of Hours:  3.00
Manual Reference:  Flaps
Brief Description:  Flap actuator connections, seals
Back to the flaps. I attached the rubber cloth to the flap hole seal brackets with contact cement, primed the parts, then installed them in the fuselage flap wells. I had already match-drilled screw holes through the fuselage skin and dimpled them. Before mounting the brackets, I cycled the flaps several times to see that path the actuator arm rods take in the hole space: I then cut that same path into the rubber cloth, then mounted the brackets and reconnected the actuator arms to the flaps.
Flap seal brackets ready for install
Brackets and actuator rods in place
Flaps are on
Flaps are on
