Brief Description: Installing the aircraft identa-plate
I have two stainless steel identa-plates for the aircraft, and we installed the smaller one. I have a larger even-nicer plate that'll go on after I have painted the aircraft some time in the future. Until then, this one will suffice and meets the FAA's placarding rules.
I located and drilled the rivet holes on the left side under the horizontal stab, and then gave Noah the honors of pop-riveting the plate to the aircraft.
Pop-riveting the identa-plate to the aircraft tail
