Sid & Houston Mayeux Project
Date:  12-18-2014
Manual Reference:  Forward Skin
Brief Description:  Creating the ProSeal gasket for the access panels
I don't want rainwater to leak past the edges of the access panel, so I'll create a permanent ProSeal gasket between the panel and the shelf doubler.
On both sides, I mixed up more ProSeal and applied it to the shelf doubler, then covered the shelf doubler area with Saran Wrap as a non-fixant. I also covered the inside of the access panel with duct tape for the same purpose. I then screwed the access panel into place to squish the ProSeal into shape. I had to be sure there wre no wrinkles in the Saran Wrap.
In a few days I'll remove the panels and all the tape and wrap, and will leave the proseal area uncovered to further cure.
Coating the shelf doubler with ProSeal
Shelf doubler and access panel anti-fixant
Access Panel screwed into place
