Sid & Houston Mayeux Project
Date:  10-11-2014
Number of Hours:  1.50
Manual Reference:  Prop
Brief Description:  Spinner prop hole backing plates, part 3
With the backing plates assembled and riveted, I riveted them to the prop back plates and rechecked alignment with the spinner...perfect.
I then reassembled the entire prop assemply and checked the tap between the backing plate and the prop. All gaps were between 1/16" and 1/8" in accordance with the plans. Moving on...
Prop hole backing plates riveted to the prop back plate...
Perfect gap between the backing plate and prop aft surface
