Sid & Houston Mayeux Project
Date:  10-8-2014
Number of Hours:  1.50
Manual Reference:  prop
Brief Description:  Spinner prop hole backing plates, part 1
After fitting and clamping the spinner onto the prop plates and "getting them close," I again used manila folder paper stock to craft templates for prop hole backing plates. I fabricated these plates from 0.063" alclad, and they fill the space between the back prop plate and the propeller. This took several trips back and forth between the engine area, the belt sander, and the scotchbrite wheel...
Fitting/spacing the spinner
Test-fitting the backing plates
