Sid & Houston Mayeux Project
Date:  8-16-2014
Manual Reference:  Cowling
Brief Description:  Top Cowl intake-to-cealing ramps
Caleb Nolan, my nephew, helped me fit/trim the upper cowl's intake ramps into place. Trimming them was a straight-forward process: We first centered them onto the intake flanges and drilled/cleco'd them into place. Then, we installed/removed the top cowling onto the aircraft, checking the ramps' clearance from the baffles and trimming as required. Once I was happy with the fit, we mixed up a thick mashed potato-esque slurry of epoxy and microfiber and applied it between the ramps' ends and the mating surfaces on the cowling, held together tightly by a couple of clecos on each end. We used Turtle Wax on the clecos to keep them from sticking. We set these aside to cure. The results were perfect!
Lower cowl holes countersunk
Upper Cowl ramps trimmed, epoxied into place
