Sid & Houston Mayeux Project
Date:  8-13-2014
Number of Hours:  3.00
Manual Reference:  Footheat
Brief Description:  Footheat air scat tube installation
I drilled/riveted/installed the footheat air intake to the right engine intake ramp, then installed scat tube to the muff intake and air intake, completing the footheat install.
Image 3 shows a white ziptie holding the scat tube to the alternator idler arm. This is temporary. When I install the alternator fanbelt and final-tighten the alternator, I'll replace the cheap white ziptie with something more durable to secure the scat tube.
Scat tube intake on right intake ramp
Scat tube routing - intake to heat muff
Temporary ziptie until alternator gets tightened down
