Brief Description: Protecting the sniffle valve and throttle cables
Per the Vans plans, I used heat wrap to protect the sniffle valve and the throttle cable where they are exposed to exhaust pipe heat under the engine. I also used a heat shield/valve clamp combo to protect the throttle cable. I just don't know how to produce any further space between these items and the hot pipes.
