Brief Description: Installing the Warning Light CBs, part 1
A few months back I had installed a fuse block on the right side sub-panel. These fuses would monitor the wires for the alternator shunt and the two warning lights. However, I had to abandon that approach because the fuse block interfered with the canopy when closed.
Instead, I ordered four 1amp circuit breakers which I installed directly in front of the pilot on the panel above the Skyview display.
Here you see me marking the drill holes using a cardboard template to mark the two end holes, then the accordian hole spacer to get the spacing exact.
