Brief Description: Fuel Pump Overflow and Pressure Sensor connections
I connected the pipet and drain line for the fuel pump overflow, and ran it down to the bottom of the firewall. Using solid aluminum tube, I crafted a dump line and secured it to the bottom of the engine mount (image 2). Image 3 shows the fuel line connection from the fuel pump to the fuel/oil sensor manifold...this line will feed the fuel pressure sensor for the Dynon Skyview EMS.
