Sid & Houston Mayeux Project
Date:  3-18-2014
Manual Reference:  Fuel Injector
Brief Description:  Installing the Fuel Injector
In installed the fuel injector...went on real slick. The mixture and throttle cable linkages will connect later. Image 3 shows the main fuel line run forward along the engine left side up tot he injector. I will replace those zip ties with adel clamps for better security.
Injector installed, not connected
Fuel line run to the fuel injector
