Sid & Houston Mayeux Project
Date:  1-25-2014
Manual Reference:  Canopy
Brief Description:  New canopy latch, part 6
I installed the latch and connected it. I had to remove it a time or two to remove material on each side at the bolt connect point: The angles ended up being too close together to allow a washer on the bolts on each side between the angles and the latch pieces...too tight. I used the Scotchbrite wheel to SLOWLY remove material until I had a snug but nice fit.
This thing looks and works great!
New latch assembled, connected
Canopy latch, exterior view, in the open position
