Sid & Houston Mayeux Project
RV-7A
Foot Heat
Foot Heat control cable
I mounted the Throttle/Mixture/Foot Heat control bracket, which hangs under the panel center bottom sill. I followed the Vans plans and ran it through one of the firewall angle pieces and connected the cable end to the foot heat flapper door.
Throttle/Mixture/Foot Heat bracket
Foot heat push-pull mounted
Push-pull cable connected to foot heat door
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
