Sid & Houston Mayeux Project
Date:  2-18-2013
Number of Hours:  3.00
Manual Reference:  Antenna
Brief Description:  Transponder antennae
I installed the two transponder antennae in the forward corners of the cockpit floor. I used RG-400 cable. The left antenna is for the integrated SkyView transponder. The right antenna is for the SkyView ADS-B IN unit. I'll remove these antenna shortly to prep for the airplane's movement to Texas in April.
Pilot-side transponder antenna hole drilled
Wires routed, antenna installed
Both antennae installed
