Sid & Houston Mayeux Project
RV-7A
Wires
Firewall-mounted ground block
I installed a ground block on the cockpit side of the firewall. The two mounting bolts pass through to the engine side, to which I connected a heavy ground cable direct to the battery connection.
Ran ground cable directly to Ground Block mount bolt
Ground Block, cockpit side
Ground wires
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
