Sid & Houston Mayeux Project
Date:  7-1-2012
Number of Hours:  4.00
Manual Reference:  Rear window
Brief Description:  Final prep on rear window
With the main canopy finally installed and the gas struts pushing them pack into their final position,
I mounted the rear window and positioned it for drilling. I used thicker tongue depressors as spacers to ensure proper gap between the front and aft plexiglass pieces over the roll bar. Image 1 shows my final edge treatment.
WIth the window taped in place over the roll bar/under the fuselage top skin, I then drilled screw holes through the plexi into the roll bar at even spacing. I started at the top and moved outward hopscotching side to side. Each hole got a cleco.
For the screw points along the rear window's side and rear edges, I match-drilled through the holes I had already drilled into the fuselage top skin. I also traced one final reference line with a sharpee along the skin's and roll bar's edges on the plexi. Once this was done, I removed the rear window, machine countersunk the holes for the screws, then enlarged the holes slightly to allow expansion/contraction space between the plexi and screw.
Returning to the sharpee mark showing the skin/roll bar, I marked a new line 1 inch inside that reference line...this is the edge mark for the black border I'll paint in with Sikaflex primer. Image 2 shows me masking that line with electric tape. I then lightly sanded that outer area, treated it with Sika Aktivator and primed it with the Sika primer. While that dried, I returned to the roll bar and tapped the screw holes.
Final edge treatment, refinement
Masking for the sikaflex primer
Tapping the screw holes
